928 - 78 - #225 Muffler and Tailpipe Tips?
A lot of work on my car has been executed in SS, like all brackets that hold the furl accumulator and filter, and lots of nuts and bolts. This will devaluate the car because they should all be original yellow cad? And those great SS solid fuel lines with high pressure flex fuel line running from fuel pump to accumulator made by Pirtek are also wrong. To me these are an improvement, for others these items will all devaluate the car.
Totally get what you are saying...^^^^^
Take my muffler for instants. Left the dual inlet, because I thought it was a much better design and helped support the weight of the pumpkin shaped muffler better. Is it correct...no. But, this system is a temporary "driver" solution and I had it from another car. Eventually, I'll put together a original style exhaust system for the big show.
Yep, there are those that believe any change is bad and those that believe certain items were meant to be replaced. Who is right...no idea...to each their own I guess.
I've always loved your car, and thought you were doing a great job on it.
Brian.
Brian.
