Intermittent windshield wiper chatter and stop position
Since I've owned the car, I've had issues with the wipers. They intermittently chatter on the windshield. I've gone over the glass with a clay bar, and tried different brands of wipers, but nothing fixes is. When there is a decent amount of water on the windshield, the chatter goes away.
Also, the wipers don't always stop in the right position... sometimes they stop ~1 inch too high. Quickly flicking the control stalk will blip the arms down to the correct resting position.
Lastly, the plastic grommets for the wiper arm where the knurled end of the motor rod goes through the trim do not align properly with the trim hole.
I'm worried that if I just take the wiper arm and move it down, that sometimes it will be 1" too low instead of too high... and will impact the trim and potentially scratch it.
Should I look into a new motor? I'm guessing the control circuit that knows the 'stop' position gets confused sometimes, and misses the mark. Only the passenger side has this issue.
EDIT: The passenger side misalignment is very apparent, as it's off by about 1" at times. The driver's side is only off by a fraction of an inch. I'm guessing this is due to the long arm on the passenger side.
I'm guessing the "only the passenger side" is about the chatter. No clue on that.
For the stopping issue, there's a series of conductor fingers and a notched conductor ring in the transmission. They dictate where the wipers stop. I'd guess you have a bit of corrosion or something on the "park circuit" bands and a simple disassembly and cleaning would help.
Thread on replacing the bearing in the motor, but it has good info on how to pull the wiper setup and a good pic of the open wiper motor & trans unit (4th pic down):
https://rennlist.com/forums/928-foru...-overhaul.html
Try waxing the windshield with carnauba wax after clay barring it. It acts like rain x when when but lasts a lot longer and lubricates the wipers pretty well.
I have the same chatter problem. Some people have suggested its from play in the bushings and pivots. I plan to remove and rebuild my assembly this winter to find out more.
Lets us know of the results if you get to if before I do.
Chronic Tool Dropper
The lubrication in the little transmission turns to soap after the lubrication part goes away with age. R&R the motor and transmission, carefully clean all the old caked mung out of there, and replace with some handy #2 red synthetic grease before reassembly. Use a little on the bushings in the arms and the pivots. With that your wipers will be smoother and faster with no chatter.
FWIW, the window motor transmissions and the rear wiper transmission all suffer from the same malady.
