928 Forum 1978-1995
Sponsored by: 928 Specialists
Pulling engine help
Old Jul 11, 2016 | 01:25 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
It looks like you have removed the tightening bolt(s) from the steering column coupler to the rack. That rubber disc in the steering column is a bit of a shock absorber, but you don't need to undo it to R&R the engine.
Do you have the eight bolts out of the motor mounts?
I don't think '84 engines had engine shock absorbers (from the front ear of the girdle to the medial lower control arm bracket). If you had engine shocks, this is what they'd look like:
Old Jul 14, 2016 | 03:48 PM
MWENDL1's Avatar
MWENDL1
Thank you again everyone. I started a new post showing some pictures of my engine as I begin taking it apart.
https://rennlist.com/forums/928-foru...-question.html
Rob: you were right. That's exactly how it looked in the manual. I just assumed that it was different due to different MY. I was getting hung up on the flywheel clearance.
Thank you for your help.
