Bulb light questions
Hi,
I own a 928 S4 1987.
I am unable to find the Dash pod **** bulb model.
Furthermore, i am not sure what is the bulb used in the hatch dome light.
Thank you !
Thank you !
Hi this may help, the list was compiled by Ken (porken) and Ed S. added LED comments.
Searching the 928 forum is always a great idea to find info too.
78-79 have less bulbs in pod. 87-88 have the same pod bulbs.
* may have to purchase 10 at a time, wholesale.
Qty | Part# | Watts | Osram | Use - Common
1 | 999 631 018 90 | 3 | 6428 | glovebox
2 | 900 631 120 90 | 2 | 3796*| red door warning
3 | 900 631 115 90 | 10 | 5008*| rear park 2, hood 1
3 | 900 631 105 90 | 5 | 6418 | license plate 2, make-up mirror 1 (no sunroof)
4 | 900 631 019 90 | 3 | 2821*| pod gauge face illumination
5 | 900 631 106 90 | 10 | 6411*| door 2, headliner 1, hatch 2 (interior lights)
5 | 900 631 102 90 | 2 | 78180*| clock 1, cigar lighter 1, rear cigar lighter 1, console AT selector 2
9 | 900 631 126 90 | 21 | 7506 | brake 2, reverse 2, turn 4, third brake or rear fog 1
Qty | Part# | Watts | Osram | Use - 2721
80-82 (warnings have brown bulb holder = replaceable bulb, can sub 2721MF)
26 | 900 631 129 90 | 1.2 | 2721*| pod switches 5, AC head 1, AC button 1, warnings 19
83-86 (warnings have black bulb holder = one piece bulb + holder)
7 | 900 631 129 90 | 1.2 | 2721*| pod switches 5, AC head 1, AC button 1
19 | 999 631 301 90 | 1.2 | 2721MF | warnings
Qty | Part# | Watts | Osram | Use - Market
North America
6 | 900 631 104 90 | 5 | 5007 | side markers 4, front park 2
2 | 900 631 126 90 | 55 | H3 | fog
2 | 999 631 127 90 | 60/40 | H6024 | headlight (sealed beam)
ROW
4 | 900 631 103 90 | 4 | 3893*| fender turn 2, front park 2 (inside fog)
4 | 900 631 126 90 | 55 | H3 | fog 2, highbeam 2
2 | 999 631 202 90 | 60/55 | H4 | headlight
Qty | Part# | Watts | Use - Dealer
80-84
1 | 928 641 959 00 | 1.2 | oil pressure (bulb w/plate)
3 | 928 641 958 00 | 1.2 | coolant temp, fuel reserve, voltage low (bulb w/plate)
85-86
4 | 928 641 983 00 | 1.2 | coolant temp, fuel reserve, voltage low, oil pressure
Soldered
PRND32 or CASIS in tach, Radio Shack #7219, 272-1092
Central warning acknowledge, seat belt, and central locking are the same as used for the warning bulbs w/plate.
________________________________________
LED from Super bright
For my 86.5 pod, the correct size was B8.5D. Hope that helps.
Ed
Indicator lights of the 80 and 84 pods take b8 4d with no modification to the hole size.
The general illumination (Gauge backlighting) lights #194 wedge
The pod switches #74 t5 wedge
DaveK9
North America
ROW
80-84
85-86
Soldered
Ed
DaveK9
