So I bought my THIRD 928 today.....
Team Owner
what do you want for the engine?
Hoi might need it for his 84 black /cork
I could use the inner door seals that run against the window ,
these are under the door panel top edges, need both doors.
The hood height adjuster rubber screws 2. could also come from the hatch adjusters
the hatch pull switch ,
the right side amp cover, bolted to the floor next to the right hand side of the passenger seat
driver side parcel tray.
thanks,
Stan
thanks,
Stan
thanks,
Stan
thanks,
Stan
Hi Stan.
I believe the amp cover is MIA but will check. The parcel tray is there, 35 dollars.
Door seals are 20 for the pair and I will throw in the 2 rubber adjusters from the hood.
Engine- hard to say when I would get the opportunity to pull it. Time is a real commodity for me. I would imagine it's worth around 750 dressed. Mileage is 76k and seems to be backed by Carfax.
Guy
Team Owner
are the arm rests in good condition?
I will take the door seals and adjusters for the hood ,
the parcel tray what color is it? or was it?
amp cover?
is there a hatch pull switch, might not be part of the 83 version,
thanks for checking
amp cover?
thanks for checking
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20160607_164818_86c80648bd5409c27002a8d7d0f3f53405cc7761.jpg)
Door panel Armrests have the typical cracking on mounts. The amp cover is missing. I may have one in my stash though. Will check. No hatch switch. Thanks.
Team Owner
I will pass on the parcel tray, and the arm rests.
but please keep looking for the pull switch and the amp cover
