Silver SFR, Any new info on your Turboed car?
I dropped by the Prototype Engineering shop today to ask the guy (can"t think of his name) if he was the one that turboed your car. He said he had talked to you. Shows that it's a small world after all. Did you get any good new information? I talked to him for a while but mainly about my projects, and his Lotus stuff. He had some pretty interesting things to say. He said that at BAE he helped put 80 turbo kits on the shelf and many 1 offs too.
Andy K
Andy K
GoRideSno,
I was able to talk to him. Fill me in on all of the information he talked about. Thanks for your help in locating him. The 928 is running perfectly. Well perfect enough.....
Thanks.
SilverSFR
Thanks.
SilverSFR
Not much of a chance, sorry Lagavulin. My ass0meter dyno does tell me at full boost (+- 7psi) @ 80 hp is what I'm getting. Is their a formula that you can get an educated guess with? Last weekend I finally got around to replacing my cracked and leaking coolant reservoir. The information at Http://www.nichols.nu/tip796.htm was a great help. Not a hard job but smaller hands would have been helpful. This weekend I will be replacing a leaky oil line between the oil pump and the turbo.
SilverSFR
SilverSFR
By SilverFSR
New HP = (NA crank hp) x (Pressure Ratio (PR))
First we calculate the PR:
PR = (14.7psi + boost) / 14.7psi
PR = (14.7psi + 7 psi) / 14.7psi = 1.48
This means the engine is ingesting nearly half an atmosphere (..with corresponding amount of fuel) more than NA.
Now all we do is multiply the PR by the NA hp, whatever that may be. In this case we'll just use the factory specified 220 crank hp:
New hp = (220 crank hp) x (1.48 PR) = 326 crank hp
Just for comparison sake, I just did the calcs on my spreadsheet which takes into account the density ratio, etc, etc.
Using 220 crank hp, 9.0:1 cr, 7 psi, no intercooler:
298 crank hp
1174 combustion chamber temp
The combustion chamber temp is pretty high if indeed there is no inter/after cooler (..and the cr is 9.0:1). Just curious, have you ever had a compression test and/or a leak-down test done on the engine?
Lagavulin,
I have not done a compression test and/or a leak-down test . The 928 has been a sunday driver and under those conditions i have not come accross detination problems. When BAE installed the turbo kit they also installed a water injection system. I currently have the system apart trying to find parts to rebuild the pump and water bottle. the 298 crank hp does not sound that far off. the boost is controled buy a wastegate. if needed, i could run the boost out to @ 9psi. If i do this detination could be a problem.
SilverSFR
SilverSFR
By Silver:
If you can't find parts for the rebuild, you could consider installing an aftercooler which is a more robust solution than what you have now for charge cooling. You could then easily turn your wastegate up to 9 psi with no problem detonation-wise.
220 crank hp, 9 psi, 9.0:1 cr, 85% IC Efficiency:
365 crank hp
1047 combustion chamber temp
That's a nice jump in power. Also notice how the combustion chamber temp dropped too, way below Corky Bell's 'magic number' of 1075.
Of course, the calcs assume 220 crank hp. Keep in mind that if an inefficiency is introduced to the engine causing a lower NA hp reading (..such as an exhaust manifold that's not as efficient), the boosted hp numbers will be lower than stated too.
That's right up there with the NOS subwoofer tubes....
http://www.crutchfield.com/S-uFfwa8t....asp?i=204NOS8
Jim(?) told me that he did not install the water injection on your car. He seems to be a fan of water injection though.
Jim(?) seemed to think that your car could handle a discharge temp of 350 degrees without any form of aftercooling. He added that cooler was better but 350 was safe.
Andy k
GoRideSno,
I just assumed that the Varajection unite was installed by BAE. I have very few service records for the first few years the car was built.
I would be very interested in your complete varajection ll. Tell me more about the Aquamist system. and how it works. Can someone please tell me what a aftercooler is?.
SilverSFR
SilverSFR
Aftercooler refers to a heat exchanger that cools the compressed air from the turbo or supercharger. Aftercooler and intercooler are generally used as interchangable terms. Aftercooler is the proper term if it is simply after the compressor. Intercooler properly refers to heat exchanger that is placed between 2 compressors.
The water injection unit serves the same purpose as the aftercooler. A proper aftercooler is superior. It is more reliable and delivers a denser charge since water molecules are not displacing air molecules.
The Aquamist water/alcohol injection system is the best unit available. It uses a special pump and a special misting nozel. Some cars in Europe come from the factory with it. I have seen them new on E-Bay for about $400 from various distributors. The E-Bay sellers have links to the Aquamist site.
HTH
Andy K
HTH
Andy K
