928 Forum 1978-1995
Sponsored by: 928 Specialists
Crazy Injectors
Old Oct 17, 2003 | 04:51 PM
John Speake's Avatar
John Speake
Joel/Steve,
I don't think cooling would extend the life of LH brains.
The problem is the IC process used by Bosch in the hybrid circuit. It's not a heat problem, it's an IC static/age problem.
Dodgy earths due to poor maintainace, arcing HT leads and surges on the battery from "rapid starters/boost chargers" can all help the ECU to fail
faster.
The earth point under the air filter can be a problem, especially if that little short heater hose nearby has split at some time, soaking it in antifreeze solution. And the MAF doesn't like that treatment either !
Regards
