Another way of lifting your car: Autolift 3000
https://www.youtube.com/channel/UCwK5qezi_vknpbSr3J9rWhQ?view_as=subscriber
I picked up this lift for $400 off craigslist. Had to drive a ways to get it though. I have never seen another one exactly like it. Herkules made it I think. The guy that sold it to me said it was Snap On, but doubt they actually made it. On the unit it is stamped DEMO. Anyways, it works great and thankfully before I bought it the airbag was replaced. I don't get under it without jack standing the arms for extra insurance. It does have safety bars in case the airbag blows. Good to 6,000 lbs
Anyone else ever seen one like this? I have searched online and never found an exact match.
Here it is after painting.
I had a man made lift fail many years ago as I was getting out from under a Pontiac Grand Prix. The rear bumper cut my shoulder. I will never use a man made stand as I am only comfortable with a car (I intend to be underneath) being perched upon pressure treated 6x6's. If ships and buildings are cribbed with them, thats what I use. The extra time it takes to mount the car is inconsequential relative to the peace of mind and redundancy. I can easily take the blocks with me wherever I go and configure the mounts as I need at the particular moment, not to mention they cost next to nothing.
Chronic Tool Dropper
^^^^ What Ed said ^^^^ Life insurance usually has a suicide disclaimer.
I've seen too many home-brew lift kluges over the years, and I've seen the pretty grizzly results when a mistake is made. Spindly pantograph arms and such won't ever be holding a car I'm under. Just sayin'...
The Max-Jax is solid, and for most things I have safety stands under the lift carriages and the car isn't very high.
I'm good with Walt's idea with heavy-duty cribbing. Done well, it will hold a LOT of weight. Lots of stacked low roll centers and local overturning moments. Done well you can't work on the middle of the car between jack points, but otherwise no worries.
+1 for the quickjack
I've been using mine for 6 months or so, on my '86S, LX470 and LS430. I paid the few extra bucks for the 7000 model. With my LX470 lifted to full height, I can barely wiggle it..
Administrator - "Tyson"
The QuickJacks are awesome, see a few at every DE event now.
I can see how you would think this by looking at the pictures. It looks larger in person and it is very heavy. I am guessing it weighs 4-500 lbs and uses very thick metal. Despite how it may look in pictures this lift is very heavy duty and safe. I would not get under a car if this were not the case.
There were 2 additional jack stands under the lift in another spot. Not easy to see in the previous picture, so here it is same night different angle. Also the lift has lockout bars for safety; if the airbag were to blow. In the front I had a large rubber bumper dock connecting the arm and lift.
This is how I use it now, to spread the weight and 4 jack stands far out for stability. It is rock solid with the 4x8's.
Here you can see the lift bars, 6 jack stands and safety bars. The arms on the lift are nearly 2" thick solid metal.
This is another way of lifting your 928.
Why you use a dead man...
https://www.foxnews.com/us/nevada-ma...ack-police-say
Nevada man died while fixing vehicle after 6.4 earthquake likely caused the car to fall off jack, police say
Notwithstanding the the extra consideration needed when using any lift or even jackstands in earthquake territories (!!!), I received some promo from Garage Equipment Supply yesterday bragging up their new MaxJax Tilt for $1399, save $100. Looks a lot like the Autolift 3000 that's the subject of this thread.
Guessing you could figure out a way to get the car sitting on 4 stands plus the lift itself for the times when your world moves unexpectedly.
