Power Steering Pump question.
I'm not sure if you've driven other 928s as a comparison. The power assist on 928s (at least mine) is fairly minimal - nothing like you'd feel in a modern car. Most people consider it fairly heavy. Keep in mind 911s from the era had no power steering. The only reason the 928 needed it was due to the weight of the engine over the front wheels. The steering weight is not too far off of a 911 manual rack from the same vintage.
1 Post
When you did the rack kit did you clock the rack before putting it back together?
When I did mine I put it back together in the position that it was in, a quick manual test on the bench indicated it was too tight. Took it apart, installed the alignment bolt in the rack and reassembled much smoother.
Resealed rack, new seals and a stronger bypass spring in the pump, rebuilt lines and a new reservoir and even my daughter is OK with the Car, it has 18's. The steering is heavier than everything else we own, although close to my sons 944. but totally acceptable.
Reservoir reportedly has non cleanable internal filter that can necome occluded. That would be first suspect.
Be sure hoses at rack are not swapped. Seems like with some extra hamfisted effort it is possible to flip them. Just sayin, probably not your issue.
When I had my high pressure line split and lost fluid you could DEFINITELY tell there was no power steering assist. I would expect the only thing that would prevent power assist from happening if you have fluid is either 1) a fluid blockage, or 2) somehow the impeller of the pump is damaged or otherwise not turning to provide power assists. Honestly, both seem unlikely, but to proceed.
The first should be easy to check just by flushing the system and making sure the fluid drains and fills without anything "wierd" happening.
Just hypothesizing, but to test if the pump was actually functioning, (and this will be messy) I think you could fill the reservoir, disconnect the low-pressure return hose at the bottom of the reservoir and plug the reservoir with a large vacuum cap.
Then if you start the car and turn the wheel back and forth you should see a lot of fluid coming out of the return hose (have a bucket handy). I'm thinking the reservoir would have enough fluid to pump for about 15 seconds - at least enough to tell if the pump was pumping.
If the pump is pumping and there is no blockage, then you really have a mystery. The only other thing I could imagine could be that the rack itself or possibly the swivel joint at the steering shaft is somehow binding up internally.
Just a thought.
Found a used pump in good condition. Installed it today and behold, power steering is good as new!
Im pleased now that most of the major dirty work, oil pan, brakes, rear main, steering, etc are now all sorted. Time to move onto the interior and electronics before eventual body work and respray.
