What is this flap / door?
In the process of trying to trace the lines for my charcoal canister re-hosing, and I noticed that there seems to be a flap/door on the left / passenger side of the firewall that has a hinge on the top and is attached above by 2 rubber grommets.
I snapped some pics of the inside the best I could with my phone but there doesn't seem to be any magic inside.
Any thoughts/ideas as to what it's for? More curious at this point than anything.
So, is that flap a "clean-out" door?
It is the drain....for all the water off the windshield which runs into the cowl area. You clean from above after CAREFULLY removing the thin black plastic partial cover .....
