928 Forum 1978-1995
Sponsored by: 928 Specialists
Rislone 4405 vs Swepco 502
Old 03-23-2016 | 03:50 PM
olmann's Avatar
olmann
Originally Posted by Mongo
I'm not sure if your 1990 928 has those rubber plugs at the back of the head under the valve covers, but my '87 does. There are threads about these plugs falling out, causing oil starvation issues to the chain tensioner. When I was in my car, the plugs were fine and I opted not to change them in 2013. However, can you confirm if your car really has the ticking lifters, and not a starving chain tensioner?
I did change out those plugs a few years ago. I'm not sure if I can tell the difference between the two sounds. I imagine it sure could be a starving chain tensioner?
Old 03-23-2016 | 04:18 PM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
I heard my chains rattle after doing the valve covers. I never changed my pads, which may come as a shock to many on here after 160,000 miles. They literally had no wear. However, The car sat long enough at an angle to cause the oil to drain from the tensioners. Starting the car after putting everything together was downright terrifying. I heard chain rattle like none other. You will know chain rattle when you hear it. My car sounded like a Mercedes 240D for a good 2-3 minutes before it cleared up.
However, with the lifter noise you're experiencing, try basic Rislone engine treatment off the shelf. This is the NON-ZDDP stuff you find in O'Reilly, or NAPA. I replaced 1 quart of Mobil 1 with one quart of this stuff in two oil changes and my noise was gone. I only put 500-600 miles a year on my car since I drive it just around the backroads and home that my oil is always clean when I drain it once a year. I have opted to drain every two years if I maintain this same mileage. I recommend giving the Rislone treatment a try for two oil changes.
The only reason my car started making lifter noise again was because it sat for about 4 months until I started it up on Sunday. After driving it yesterday, the noise is gone, but I'm still dropping in the Rislone with ZDDP in it from now on.
Quick Reply: Rislone 4405 vs Swepco 502
