928 Forum 1978-1995
Sponsored by: 928 Specialists
Just found this behind the glovebox.
Old 03-22-2016, 02:24 PM
Whitesands
Whitesands's Avatar
Default Just found this behind the glovebox.
Looks another bit to sort out.
Old 03-22-2016, 02:48 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
That is your alarm brain with likely are connectors associated with an after market alarm
Old 03-22-2016, 03:42 PM
davek9
davek9's Avatar
Yep I've seen the same on my gold 86.5, right b4 I replaced the wiring
Also found a sticker behind the CE saying the aftermarket equipment was not compatible w/ German cars !!!
No wonder the pwr locks didn't work.
I would clean that all up and make nice clean solid connections WYIT.
Captain_Slow
Captain_Slow's Avatar
I'm very familiar with those clip-type connectors. I've removed many over the past month. https://rennlist.com/forums/928-foru...scratcher.html
Your alarm controller is clipped to the body bracket and the clip has scratched it. The alarm controller is not in this location on my car and the bracket is unscratched, leading me to conclude the factory installed it in one of the other known locations. I found it deep down and within the center console, with the blue connectors facing the firewall. The hacking of my alarm system therefore did not happen so close to the controller. I feel a separate alarm thread coming...I'm kinda surprised the car starts normally and so far no other ill effects after removing the cheap alarm.
I removed all clip splice fittings and bandaged the original wires with electrical tape.
Old 03-22-2016, 03:48 PM
davek9
davek9's Avatar
I think the Alarm controller was moved on the S4's to the center console Jon, not sure what year.
Dave
Old 03-22-2016, 04:12 PM
Captain_Slow
Dave- Could it be that the location is inconsistent during a period of production overlap? I've heard stories of early 88s (which mine is) having lots of on-the-shelf leftovers installed. Ivan's is an 88 S4, too.
For those who may be curious, the alarm controller in my car is larger and the case is aluminum (silver box under the black plastic air handler). Something to keep in mind if you don't find it behind the glove box or under the passenger seat.
Behind the glove box I found the same bracket, a common location for the alarm controller. Note Ivan's is scratched by the clip securing the controller to the bracket. The bracket in my car is unscratched and there's no wiring in the area. This lead me to look elsewhere.
Old 03-22-2016, 05:42 PM
Whitesands
Whitesands's Avatar
Build date on mine is 11/87.
Old 03-22-2016, 06:22 PM
Captain_Slow
Mine was built in 7/87. EDIT: I goofed...skip to last post.
Last edited by Captain_Slow; 03-25-2016 at 06:41 PM. Reason: One should always check option codes
Old 03-22-2016, 08:27 PM
ltoolio
ltoolio's Avatar
The silver box under the air handler is an alarm? I have what appears to be the same box on my '82 and I didn't think mine had an alarm in it...
Old 03-23-2016, 06:47 AM
The Forgotten On
The Forgotten On's Avatar
It's actually the cruise control unit
Old 03-23-2016, 10:33 AM
Captain_Slow
Skip to last post...
Old 03-23-2016, 11:13 AM
Ducman82
Ducman82's Avatar
yup that box is the cruise control brain..........
Old 03-25-2016, 06:31 PM
Captain_Slow
Oops...No mystery here. My car doesn't have a factory alarm.
Quick Reply: Just found this behind the glovebox.
