928 Forum 1978-1995
Sponsored by: 928 Specialists
Center vent microswitch
Old 03-22-2016, 01:12 PM
Whitesands
Whitesands's Avatar
Default Center vent microswitch
While fixing a problem with the interior cabin sensor I tested the microswitch in the center vent and found its stuck in permanently on position telling the rest of the system that the vent is closed even if I have the vent open.
What effect does this have on the rest of the system? Just my curiosity I guess.
I have a new switch to replace it.
Thanks.
Old 03-22-2016, 01:22 PM
joejoe
joejoe's Avatar
It will close the 'comb' flap and push air to door, floor or defrost.
Old 03-22-2016, 01:48 PM
Captain_Slow
Captain_Slow's Avatar
Ivan - Can you post a photo or describe where this micro switch is located? I just replaced my comb flap and footwell flap actuator diaphragms over the past few days. I'd like to check this before reinstalling the console.
Old 03-22-2016, 01:58 PM
Whitesands
Whitesands's Avatar
Sure,
Old 03-22-2016, 02:01 PM
ammonman
ammonman's Avatar
IIRC on my 1990 it also switches the center output to cool air once the cabin is near the set temp. Thus means the driver and passenger get cool air in their faces even though the cabin is being heated. Nice feature when my wife is feeling a little over-heated and slightly motion sick.
Mike
Whitesands
Whitesands's Avatar
If you need one any electronic shop will have one, I got mine off fleabay.
Ivan.
Old 03-22-2016, 04:22 PM
Captain_Slow
Sorry...just realized the micro switch is in the console side of the vent.
Last edited by Captain_Slow; 03-22-2016 at 04:25 PM. Reason: Oops...micro switch is on console side
Old 04-04-2018, 12:35 PM
davek9
davek9's Avatar
Does anyone have a pic of the underside of the console for mounting of this micro switch?
I'm putting my console back together and the switch and all the other moving parts were bagged up, 3 years ago
Thank you,
Dave
Old 04-05-2018, 09:41 AM
gomez123
gomez123's Avatar
Old 04-05-2018, 09:55 AM
davek9
davek9's Avatar
Thank you Gomez123, that is almost what I'm looking for however I think that is an earlier model than MY86,
My switch sits inside like in the pic in post #4
I need a pic of how the micro switch is mounted to the console, I think I have a broken tab for the mounting bolt, and need to make a new mount.
Thanks again for the assist
Dave
Old 04-05-2018, 10:12 AM
gomez123
gomez123's Avatar
Yes it's a 1982.
Old 04-06-2018, 05:09 PM
davek9
davek9's Avatar
Update, I was able to use a screw and fasten the switch mech down to the vent, worked out great.
Thanks again,
Dave
Quick Reply: Center vent microswitch
