Shock Q
Any advice is much appreciated. Many thanks,
Steve
'89 S4 Auto
Can't say that I noticed much (if any) difference between the Boge's with 125k on them and the new Bilsteins. Unless you are unhappy with the Boge Reds on your car for some reason, with only 86k on them, they should be good for many more miles. I drive "enthusiastically" and Autocross regularly.
I think the Boges are too floaty, red or black.
The Konis are good BUT if your using the Boge spring adjuster collar inner threaded rings, They dont lock onto the shock tube so you cant adjust them once they are put together. so you better have the ride height dialed in or you will taking them apart to make adjustements
If the Konis come with their own adjuster collars this will be another story but I dont believe they do. The Bilstiens come with lower perches and adjuster collars
Koni internally adjustable - set of 4 - $660
Bilstein - set of 4 - $928
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
