Windshield wipers 82 928 s euro
Wipers would not work, if you run a hot wire to switch they will work at one speed , changed out two relays and still won't work, put old relays back in and will will not work, only get one speed with a jumper wire hooked up, could problem be in the colum switch itself , is there a way to check switch or get it rebuilt, have not been able to locate one
Your problem could be the switch. Have you tried putting power directly to the plug? I don't remember the pinout offhand, but you can apply power to one, two, or three (the correct ones of course) plus ground to test the motor itself.
Have you tried 928 International for a used switch?
The multi-switch spans several years, IIRC. "Early" switches fit all the older bodied cars...
I think.
I think.
I think.
I think.
The speed control on the wipers is accomplished by having multiple hot inputs. The switch controls how many get power, which gives the different speeds.
