What size performance tires for 18" Panamera rims?
#46
I'm in the process of looking for DOT cert. track tires for a set of Panamera 18" 10 spoke that I just picked up for the '88. I'm leaning in the direction of Toyo Proxes R888.
I gather that there's a consensus that the "safest" tire sizes of 235/40 for the front; and 265/35 for the rear will work well on all generations of 928's - at least the S4.
I'd also heard somewhere that if balance between front to rear circumferences of an aftermarket wheel set varies too much from that of stock, that it may disable the ABS. Is that true?
The circumferences of the 235/265 setup (“NEW”) will be close to that of the factory original S4 specs (“EXISTING”), and the front to back circumference variations are nearly identical to factory.
Front 235/40 comparison to stock:
Rear 265/35 comparison to stock:
The R888 are available in these sizes.
But I'm considering going 10mm wider; front and rear and adjusting the aspect accordingly.
Front 245/40 comparison to stock:
Rear 275/35 comparison to stock:
The circumference difference between front and rear is nearly identical to the 235/265 combo, but but the speedo error is a bit higher. R888 are available in these sizes as well.
It looks as though the 245/275 combo. would work well with the 8"/9" wheels, if I were to go with the R888.
Anyone think otherwise?
#47
Here's factory setups and some aftermarket sizes what work. I like to run 2-3% larger than stock diameter rubber so that speedo is dead accurate. Naturally wheel width determines how wide rubber can be. More hardcore driving wider wheel needs to be compared to tire width and narrower rubber needs to be compared to wheel width.
Code:
Factory front Sidewall Radius Diameter Circumference Revs/km Difference 225/50-16 112mm 316mm 631mm 1984mm 504 0.0% 225/45-17 101mm 317mm 634mm 1993mm 502 0.5% Aftermarket front 245/45-17 110mm 326mm 652mm 2049mm 488 3.3% 255/40-17 102mm 318mm 636mm 1997mm 501 0.7% 225/40-18 90mm 319mm 637mm 2002mm 500 0.9% 235/40-18 94mm 323mm 645mm 2027mm 493 2.2% 245/35-18 86mm 314mm 629mm 1975mm 506 -0.4% 255/35-18 89mm 318mm 636mm 1997mm 501 0.7% 265/35-18 93mm 321mm 643mm 2019mm 495 1.8% 275/35-18 96mm 325mm 650mm 2041mm 490 2.9% Factory rear 225/50-16 112mm 316mm 631mm 1984mm 504 0.0% 245/45-16 110mm 313mm 627mm 1969mm 508 -0.7% 255/40-17 102mm 318mm 636mm 1997mm 501 0.7% Aftermarket rear 275/40-17 110mm 326mm 652mm 2048mm 488 3.2% 275/35-17 96mm 312mm 624mm 1961mm 510 -1.1% 275/35-18 96mm 325mm 650mm 2041mm 490 2.9% 295/30-18 88mm 317mm 634mm 1992mm 502 0.4% 315/30-18 94mm 323mm 646mm 2030mm 493 2.3% 335/30-18 100mm 329mm 658mm 2068mm 484 4.2%
#48
For those of you wishing to add spacers to the rear Pana wheels, I've done it on my S4. Here are the results:
https://rennlist.com/forums/928-foru...l#post13668262
