928 Forum 1978-1995
Sponsored by: 928 Specialists
928 OB VIN Decode
Old Feb 28, 2016 | 04:21 PM
antlee928's Avatar
antlee928
Default 928 OB VIN Decode
Hi,
Considering a project car with following VIN and (possibly) Engine #
VIN 9288101049
Eng # (???) 9281011065 RM
Supposed to be an Australian delivered 1978. Appreciate some assistaance with the decode.
Cheers
Tony
928 S4 MY89
Old Feb 28, 2016 | 05:08 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
For better or worse the only folks that will have the options data on that car is Porsche, via ordering a COA.
Old Feb 28, 2016 | 07:59 PM
GlenL's Avatar
GlenL
https://www.stuttcars.com/technical/vin-decoder/
It's a 78 with the lower-power engine which may say it's a US. That engine code should have some punctuation and spaces. Look for a square boss on the top of the engine just to the right-side of the upper hose. (you'll probably be looking to the left)
https://www.928gt.com/t-928engine.aspx
Old Feb 28, 2016 | 09:03 PM
Dave928S's Avatar
Dave928S
The VIN confirms it's a '78 as already noted. The VIN is within the range which confirms it's a euro (Start:9288100011 End:9288102646). Engine # ... can you take a photo as I think one number might be wrong and there should be some spaces that are meaningful .. think it might be a 5 speed.
That's all I have.
Old Feb 29, 2016 | 01:04 AM
Vilhuer's Avatar
Vilhuer
Engine number seems like cast number in some part. Proper engine number is totally different layout and starts with M28...
Old Feb 29, 2016 | 05:46 AM
928cs's Avatar
928cs
With a manual car, the engine number should be something like M28/01 818 ???? .
Old Feb 29, 2016 | 06:40 AM
The Deputy's Avatar
The Deputy
Hope it checks out and you take on this endeavor.
Pictures would be nice, inside and out, if you get a chance.
Brian.
Old Feb 29, 2016 | 07:02 AM
Dave928S's Avatar
Dave928S
Tony ... as Errka and Samuel have said, the engine number for a 78 manual has to be M28.01 ... and I would expect to see below that the serial number as a separate line and have seven digits. As that number should start with an 8, I was thinking there might have been a transcription error, and perhaps there were some others added. Only a photo will clear it up. Stand at the front of the car, and look just in front of the water bridge, to the left of the front of the motor ... that's where the number should be with M28.01 top line and then seven digits below with no spaces. If that's where the numbers you quote are, then something funky is going on.
Edit: Just saw the number confirmation in the other thread (928 101 1065RM), and with those spaces and beginning with 928, it sure looks like part or, more likely, a casting number. Further edit ... I think you may be looking at a head casting number, which fits that format.
Old Feb 29, 2016 | 03:26 PM
antlee928's Avatar
antlee928
Thnx Dave. I am looking at pics taken by owner as car is interstate. I feel you are correct that this number is some form of casting number. You are corre t that engine numbers start with an M28. Just thought it may have been different initially with these very first cars just like the VIN #.
Thnx for your help.
Cheers
Old Feb 29, 2016 | 03:28 PM
antlee928's Avatar
antlee928
Dave, do you know if these cars came with a manual sunroof option as this car has a manual sunroof according to discussion with owner. Never heard of it and am wondering if this may have been an aftermarket addition?? What do you think??
Cheers
Tony
Old Mar 14, 2016 | 06:07 AM
Hilton's Avatar
Hilton
Did you buy it Tony? I was tempted but convinced myself I didn't have room in my life for another project car.. there were a few engine bay bits missing in the photos.
Old Mar 14, 2016 | 07:08 PM
antlee928's Avatar
antlee928
Hey Hilton. No I didn't buy. Spent some time talking to seller. He had bought it to replace the engine with a 4.2L Toyota V8. He has a Soarer and loves the engine in these cars. He says he then realised what he had and decided he would sell and buy a later model (maybe S4). Makes me wonder if he knew something I didn't. He did say if it didn't sell then he would keep. It had a new(ish) leather interior than standard. It was an Australian delivered car. However some previous owner had put in a manual sunroof - pop-up I believe and so the seller commented. Anyway no cigar here and may represented a lot more work although price was reasonable and not much above what the seller paid. Maybe I will contact him to see if still available??
Cheers
Tony
Old Jun 26, 2016 | 06:05 PM
cnpapa24's Avatar
cnpapa24
Owner turned down a high bid of $32,500. That would have been $35,750 all in.
http://www.auctionsamerica.com/events/feature-lots.cfm?SaleCode=CA16&ID=r0228&Order=runorder&feature=&collection=&grou ping=&category=vehicles
Old Aug 12, 2018 | 01:34 AM
John Carlin's Avatar
John Carlin
7th Gear
I'm eyeing off a second 928 and am hoping someone might be able to help decode the following:
WP0ZZZ92ZDS840502
Thanks in advance,
John.
Old Aug 13, 2018 | 10:24 AM
Wisconsin Joe's Avatar
Wisconsin Joe
Try here:
https://rennlist.com/forums/928-foru...l#post15208832
You have a later, 17 digit VIN. Maybe an 83 ("D" in 10th place)?
