I did a search and couldn't find anything on this. My hatch release opens the hatch perfectly but as soon as I release the button the motor stops, it doesn't return to the rest position. So if I don't hold the switch the right amount of time the motor stays in the released position and the hatch won't latch shut. So then I go back and pull the switch for a second or two and then I can properly close it.
Is this something in the motor that can be repaired?
I forgot your Year Model, Check fuse #24 if 87-89, or #25 if later.
Cheers,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor www.928gt.com
It's an 88. So that fuse just operates the return to rest circuit?
Correct, plus your interior lights may be out and most likely blew the fuse. I am assuming your already checked #26 which is main fuse for Hatch release.
Checked my ce panel and that fuse was missing! I happened to have a 1a fuse from when I had my previous 928, plugged it in and voila the motor returned. Thanks for the help, I didn't think of the fuse panel being an issue because the hatch actually worked!
Gosh, that was easy. I've avoided dealing with the same problem. I still need to overcome my CE panel phobia - I've owned my car 18 months without opening it.
