Door Won't Open
Door Won't Open
Hi Guys,
I've tried search but came up with...well not much. Passenger door (RHD) won't open and is locked. I cannot unlock it with the key or the rotary ****. Does anybody have any ideas?
Scott
Scott
There is a little rod that comes out through the top of the door panel above the rotary ****. Pull it up and pull the door handle at the same time to see if that will open it.
If that works, your door lock motor is out of adjustment and is binding up the door mechanism. In which case you will need to adjust it.
If that doesn't work, I don't know what else will aside from tightening the door handle cable.
