random idle
Upon another trip from the Bay Area to LA and back my '80 has developed a random idle pattern. It will run up to 1500 then back down to around 800 after a few minutes from a cold start. Then it seems to settle in around 1200 -1500 or so once warm
Is this a sensor issue?
1980 the auxiliary air valve sets the high cold idle then gradually closes down the bypass as it warms up. It has a spiral spring inside which gets heated by an electrical current. It moves rather slowly.
If it will not idle down when hot and oscillates I would suspect an air leak.....unmetered air like from a split intake runner boot. That would lean out the mixture making it run poorly cold and letting it idle too high.
I replaced the vacuum limiter and I still have a random idle at start then a high idle from then on.
If I run the engine for 5 hours straight it still stays up. A bit better in warmer temps like LA mid 80's it will drop about 100 revs.
Is this a vacuum leak?
