Striped cam retainer bolt
Well the motor is out and I am in the process of removing my cams, to replace a broken chain. Nothing is easy...I striped three cam retaining bolts..
My question, do I have any option other than drilling these puppys out? Any other ways to remove them??
Captain Obvious
Super User
Super User
Drill the head off and then rest will come out easily. Tilt the engine so the shavings fall out instead of in the engine. Also, cover everything with rags to minimize contamination. If you have any that are untouched, tap them first with a small hammer and the tripple square bit and then try loosening them. The S4s have these idiotic boots that work well during assembly but are a nightmare later on during service. If you can, I would suggest to replace all of them with allan head bots.
Drill it out Kent, not much you can do at this point. Cover every MM when you do. I usually have a couple of magnets sitting on the towels I have covering everything else to help catch the drilled shavings.
Also, it helps a bit to have some valve grinding compound on your triple square bit to help grab as you try to remove them.
Let me know how many you strip, I'll send you some for the price of shipping. Unless you say you stripped them all then I"ll charge ya 1/2 price
Captain Obvious
Super User
Super User
If you have a bench grinder, scrape up a bit of the grinding dust, mix it with some grease and you made yourself some home made valve grinding compound. Unused this once on a project car when I ran out of compound. Worked like a charm.
I'll see what I can drum up
Archive Gatekeeper
Any reason one couldn't slot them with a dremel and use an impact driver with a bigass slotted bit to back them out? Drilling the head is probably quicker, tho.
Damn XZN bolts....
Damn XZN bolts....
As Stan would say. NOTE: get a properly fitting tool.
Archive Gatekeeper
The first engine I took apart I mangled a bolt or two, so I splurged on one of the Hazet sockets and haven't had any issues just zipping them out with an impact. Have probably taken 6 engines apart by now. Though it occurs to me they're always out of the car....
Why not use an easy-out?
Yes - i love them - period. Preferred over drilling any day. Very handy for rounded allen's like those that mount the seats.
