Different 3-speed auto problem: slipping cable? into park?
Hi all-
Searched as best I could and couldn't find this specific problem:
1982 928 ROW non-S auto
Shift lever works fine through all gears but when pushed forward to Park stays in Reverse all the way and has a different feel. While nominally in Park you are still actually in Reverse.
I presume there is a cable that's slipping in a fitting or similar? Where would it be, how do I access it, how do I fix it?
Thanks!
ACP
Thanks!
ACP
No quick answers? Should I be worrying?
I should add the selector works fine through all the other gears and the car drives fine. Lever just won't carry whatever it's articulating forward into Park.
ACP
ACP
There will be a cable adjustment bracket (clamping the cable outer) at the lever end under the shifter.
Do the other positions that work have the gear indicator line up ok, or is it a bit off?
I dont recall how the cable attaches at the box, and the WSM doesnt show it that I can find.
PET shows the cable outer having a threaded section that allows for adjustment, right side of box. Ball coupling on shift lever.
Having it still in R when you think its in P could lead to some problems....
WSM, page 37-11, Vol2 Trans. Right side of box. Disconnect ball coupling cable to lever; move selector to N inside car; move lever on box to N (of 1,2,D,N,R,P, front to back); adjust cable so that coupling engages without tension.
jp 83 Euro S AT(3sp) 56 k
