PSD question
PSD question
When I was changing the flex soft PSD hose under the car last time, the PSD fluid was keep coming out from the hose non stop until the PSD fuild reservoir was empty. I am wondering if the solenoid valve is faulty because it should kept close when the car is shut off.
Any comment please. Cheers
91 S4
91 S4
Are you talking about the hose with an "X" on it? If you removed that and the reservoir drained… there's this guy named Wiley Coyote that had similar problems. Anyway, I’m thinking you’re talking about another soft hose, but these two blue ones are the only soft hoses I can think of Or maybe you're referring to the one connected to the control valve--near the transmission(?)
