928 Forum 1978-1995
Sponsored by: 928 Specialists
First gear knock
Old Dec 11, 2015 | 03:58 PM
bran3b's Avatar
bran3b
Default First gear knock
I am positive that I read that answer to this question here recently, but I can't find it now. As I recall, what I read was that it is somewhat normal for 1st gear in my '79 5-speed to have a knock at low speeds. I can only hear this if my window is down and I am next to a wall.
Is my memory correct or was this all conjured up in a dream? Of the 3 running 928s that I have, all 3 make the same noise.
Old Dec 11, 2015 | 04:19 PM
James Bailey's Avatar
James Bailey
not normal but not an uncommon problem as the spacing of the reverse gear gets messed up and the edge hits a gear when in 1st...
Old Dec 11, 2015 | 04:20 PM
bran3b's Avatar
bran3b
Thanks. This has been driving me nuts.
Old Dec 11, 2015 | 04:23 PM
James Bailey
Yes makes you quick to shift into second...
Old Dec 11, 2015 | 04:25 PM
bran3b's Avatar
bran3b
Will this cause damage or is it just annoying?
Old Dec 11, 2015 | 04:31 PM
James Bailey
chips the gear teeth on the edge.....
