79 CIS tach signal shape?
Has anyone captured the tachometer signal for the early CIS cars? I am trying to understand the fuel pump cutoff circuit inside the fuel pump relay but I can't make sense of it based on a 0 to 12v square wave.
Any help would be appreciated.
Brian.
Brian.
Considering the distributor is producing RPM x 4 pulses I'd be surprised if the box was multiplying it that high. Or multiplying it at all.
It is a square wave signal.
The distributor is rotated at 1/2 engine speed.
Count the contacts in the distributor to determine how many pulses per revolution then *desired rpm.
