HEADLIGHT AMPERAGE QUESTION
Guys,
I've done Search but could only find a comment from 2004 that stated he found the headlight amperage to be 'over' 20A when on even after the motor raised them.
Would anyone know the amperage for the headlights when illuminating with an incandescent bulb ?
Thanks in Advance.
Craig
Thanks in Advance.
Craig
Stock fuses are 7.5 A per side for low beam, and 15 A for the headlight motor. So if 20A was measured for headlights only, then there is some serious draw somewhere or significantly brighter bulbs must be installed. Possibly it was total draw measured including the tail lights and side markers?
Cheers!
Carl
Cheers!
Carl
Electron Wrangler
Of course it depends on the bulb... And remember you don't have a 12v system when the engine is running. Stock H5 bulbs are 45W low beam (65W high beam). So close to 4A per side for low beam - there is a 7.5A fuse per side.
On initial turn on when the filaments are cold the current will actually be much higher - closer to 40A for a very short period until the filaments reach working temperature, too fast for a normal fuse to react (for the same reason). A fast reading meter with a peak current feature might well capture that. (This is for much less than 1 sec)
Alan
Alan
Alan
Alan
Alan, does the current to the lights and motor flow THROUGH the relay, or does the Head Light relay just switch the circuit with the current to run the appliance coming from outside the relay ? I ask this for if there is this brief (msec) high amperage involved with the bulbs, might this high amperage ware on the relay over time ? If the appliance current runs through the relay, activating the headlight motor will compound this high amperage exposure too.
Your thoughts...
Electron Wrangler
There is a different pair of relays for the motor - these are integrated into the headlamp "relay" but they are quite separate from the other 2 relays for the headlamp bulbs (On/Off and Hi/Lo). So the headlamp relay actually has 4 relays integrated into it (only 3 - a single motor relay for the non-reversing pre S4 systems.
Alan
Alan
I take it that an 8" H4 with a 100w high beam bulb ( Low 55w) is going to suck a lot of amps, but since you are motoring along at speed you should be generating enough to not be a problem?
No, it's not really a problem. I just want to go with more efficient illumination in terms of my alternator output. I'd rather exhaust 2.5 amps with a LED than 8 amps with a 100w incandescent.
Electron Wrangler
Alan
