Brake Lines, which do you prefer?
Does everyone go with OEM or after market for everyday road use? When I say after market I do not mean the steel braided lines, as I have read that there is no benefit for those on a regular road use. Thanks.
Basic Sponsor
Stock lines are OK and available OEM - Fronts are about $75 each and rears are $35 each.
We sell complete sets of SS braided for $85.
You can also buy Aeroquip sets of hoses from Mark or Greg for $160 ish.
Chronic Tool Dropper
The Goodridge braided lines participated in a pedal firm- up on my street-only car. Vs the 90k plus 20 years on the originals. A worthwhile improvement IMO.
Get the rubber lines. OEM or what?! I've never thought to care.
The SS lines are prone to aging far faster than the rubber lines. I've got them on one car and replace them every 1-3 years. Went with new rubber on the other to save money and hassle, long-term.
Basic Sponsor
On the fronts there is only Porsche.
Rears are Ate OEM or Porsche. Not a lot of manufactures making 928 brake hoses when most use after market PTFE with SS Braided sheath..
Basic Sponsor
A problem is that the DOT standards were written around rubber lines and the tests don't inflict fatigue on the hoses. I looked them up. They test burst pressure and flexibility but there's no testing for thousands of pressure cycles or use in cold climates.
I admit that I looked carefully at the flex especially on the fronts, and fitted up some tubing over the first few inches of the braided section below the crimps so the flex wouldn't be so localized. Weapon of choice for me was some poly ribbed wiring cover, the split tubing stuff, held on with zip ties top and bottom. The lines are inspected at least annually.
I was doing a whole brake system refurb, part of which included purging some fugitive air from the system. I take the blame for putting the air in there, BTW, during an annual fluid flush. Anyway, pedal was a little soft and a little low. With the hoses and a bunch of intensive backwards-bleeding section by section, edal is very firm and right at the top of the travel range for engagement. So I can give some of the credit to the new hoses.
Nte that the factory hoses aren't a lot different from the braided SS ones -- They just have another rubber covering over the braded reinforcement, and an extra layer to swage under the fitting. I'd have no issues with either the stock or the Goodridge. Sounds like there are other choices now through Greg and Mark.
