Seasonal Oil Change
Mike, I had the same problem with the old Volvo our winter car. The steel brackets holding the fuel tank were almost broken from corrosion. Fabricated new stainless steel brackets which is a huge improvement. I do not know anyone over here using their "fine" automobiles during the winter months.
An old Volvo or similar is the way to go.
Åke
Åke
It can be a bit tricky juggling 2 cars in Edinburgh city centre due to parking restrictions. I'm also not doing enough miles to really justify a second car. At the moment I walk to work so won't be doing too many winter miles this year. Also if I bought a second car I would probably end up with another porsche or a lotus or something. Really want a lotus Esprit but not sure it would make a good winter run around.
we use 0w40 in the vehicles we drive in the winter including the Cayenne.
Its brutal on any vehicle starting them when the temps are -20c and below, yikes!
Chronic Tool Dropper
I drive my S4 all year round but don't do enough miles to warrant changing oil seasonally so I use oil that is suitable all year around. At the moment that is millers 5w40. Started the car many time in sub zero temps and always get good oil pressure. I do however see hot oil pressure just under the 2 bar mark on the dash. I'm considering trying a 5w50 next change either millers cfc or valvoline vr1. Why not just use an oil that is good all year? What is the downside of a 5w50 vs 20w50? Surely it's the same viscosity when hot but better cold start protection.
As for salt on the roads. Yes that's a problem here in Scotland. I've replaced my fuel tank cradle which looked like it was about to rust out, fuel lines look suspect in places, suspension looks pretty rusty. I now spray everything under the car with Acf50 in the hope to slow down /prevent further rust.
oil preference sure brings 'em out of the woods. When I bought my 79 I asked the PO what oil he used in it.
He said Castrol. It had a little clicky problem and I changed it to valvoline 20-50 semi synthetic. -cleared right up. Been good since. I also store mine during the cold months but don't bother with an oil change. I make sure to drive it long enough before parking to cook the moisture out. I have too much machinery in my mini Leno's garage to be doing annual changes. I go by time intervals, including the airplane.
Bob, I'm sort of with you, but figure that for the cost of the oil change (~$40), it's better to just get any acid components out before hibernation. To each their own.
Pumpkin has a pretty high moisture content.
Malcolm, other than the Cayenne, what vehicles are those, and what does does the Cayenne's Owner's Manual call for?
