Missing when cold.
Hi,
The last 3 or 4 times I drove my car it as developed a slight miss when cold.
It starts fine, idle is steady, if accelerate with car stopped there is no miss, only in the first 4 or 5 minutes driving after start up, whether the accelerator is pressed hard or smoothly.
It doesn't need to reach normal operating temperature to get fine, only a few minutes, and after that even if stooped and start again everything is ok!
TIA for our opinions!
Regards
Regards
Hi Jeff,
Thanks for your answer!
As a matter of fact I have a Temp II sensor with respective gasket, new in the box, never installed!
Do you believe a faulty one could give those symptoms?
Is it easy to replace?
Just to confirm, number 33 and 32 (gasket) in the diagram, correct?
Regards
Regards
