Was doing some more clean-up under the hood and decided to clean up some electrical messes.
My Temp Sensor currently has a couple of exposed spliced female connectors to it, which doesn't really feel like the right way to have them connected.
Is there a standard connector that you may have used to fix this? I've searched around out on Amazon, Summit, etc and can't find anything that seems to match.
For reference, pic of what I'm trying to connect to is below. One of the spades is larger than the other, and the Bosch Female Ignition connector doesn't seem to be the right part.
factory used 2 female spades, works like a champ. rebuilt ones are the same. maybe you could find some sort of motorcycle light connector, or a modified trans neutral switch plug of some sort? but id just do new terminals and call it a day.
I've got a couple of insulated female connectors all ready to go, crimped and heat shrunk onto some wire, but just wanted it to look clean/original (damn OCD).
Good suggestions about the alternate connectors...off searching I go.
We stock the spade connectors and the right angled insulation covers 8>)
