Odds and Ends F/S
All plus shipping ... pls PM for any specific details, and thanks for helping me raise some more funds to give to Roger & Sean ;-)
[SOLD] $10 ea - USED window and sunroof switch - 4 wire type, window switch is missing the connector. Got these in a parts 'grab bag' from another Rennlister, don't know condition
$15 - NEW hood release plastic backing plate
$10 - NEW Oil filler O-Ring
[SOLD] $7.50 - USED ground strap, worked fine, replaced as a preventative measure
$10 ea - Two NEW airbox rubber mounts - 30mm dia, 30 mm tall, 7 mm hole. I believe these are used on S3, I bought based on a post here on Rennlist but found not needed on my car
[SOLD] $25 - USED ignition switch from my 150k mile GTS. Replaced while troubleshooting a no-start problem; problem was elsewhere so assume still good
$20 - NEW stereo connector. This is the female side that lets you connect a head unit to the car wiring without modification
$25 - Replated power steering pulley and three bolts/washers
[SOLD] $15 - Replated hood latch
[SOLD] $50 - Full set, S4+ replated cam cover bolts and washers - 26 long, 8 short and 34 (or more) washers. Also includes a pile of the black rubber seals that may or may not still be good
Been using Arrow in Ft. Worth. They are pretty quick and good to work with. I think minimum order is something like $45 and they treat small items (fasteners) and large items as separate orders. For example, the power steering pulley went into a 'large item' batch and the bolts/washers for it in a 'small item'.
So far, always got back everything I sent!
