928 Forum 1978-1995
Sponsored by: 928 Specialists
help identifying some PO presents.
Old 09-20-2015, 08:46 PM
sydneyman
sydneyman's Avatar
Default help identifying some PO presents.
Ok just did an intake refresh and now im going through the grounds etc. ill probably start a new thread about that but in the meantime came across a few odd things.
The first pic is of a harness that was electrical taped and sitting on the passenger side lower dash shelf. It has two connections as you can see and one of them is jumpered... didnt see anything around or behind the fuse panel that was obvious so figured id ask.
The second pic is obviously by the battery post. Theres a green wire with a single spade connection. Again, nothing obvious to plug it into.
And btw all my grounds looked great until i pulled them off and they crumbled in my hands... its nice the dealer can still source all of them for fairly cheap!
Old 09-20-2015, 09:03 PM
G.P.
G.P.'s Avatar
The 1st pic looks like the old anti theft alarm module has been removed and the fuel pump immobiliser section has been jumpered. This is normal as the old alarms will eventually fail and leave you stranded, and the fuel pump will not run without the jumper wire.
Old 09-20-2015, 09:25 PM
sydneyman
sydneyman's Avatar
ahh that would make sense. And thats great news if thats the case. something less to worry about. Thanks GP! and for those that dont have sigs turned on, its an '85 32v 5 spd.
Old 09-20-2015, 09:34 PM
Bilal928S4
Bilal928S4's Avatar
The other picture looks like the connection to the compressor. It signals the clutch for the compressor to get energized.
Old 09-21-2015, 04:47 PM
carnahanbb
carnahanbb's Avatar
It's funny but I just came across the exact same thing in your first picture. I posted the same question in another thread and no one ever figured it out. Good to know!
Old 09-21-2015, 05:02 PM
AO
Supercharged
AO's Avatar
Yup. AC connection.
Old 09-21-2015, 07:17 PM
sydneyman
sydneyman's Avatar
obviously those were too easy! Heres two more that i found today!
Both are in the rear of the hatch area just under the rear wiper motor... Im not sure what the 4 prong oblong plug (with 3 wires) should go to and also that relay.
Thanks everyone for helping me out!
Old 09-21-2015, 07:58 PM
sydneyman
sydneyman's Avatar
also, whats a good way to test the speedo connection at the transaxle? are the top and bottom sensors both for the speedo?
SMTCapeCod
SMTCapeCod's Avatar
A/C connector was ID'd in one of Ken's posts as an unused connection absent the two package, wherein it triggered aux fan based on trans temp. or something like that. But it wasn't the main compressor incitor.
Second wire bundle- appears that your remote hatch release motor is absent, so I'm betting that is the wire harness for it. I expect the PO derived immense satisfaction removing the motor, indulging in a big wind up, and whipping it against a more solid object meeting the fate that many feel it deserves.
Old 09-21-2015, 08:33 PM
PorKen
Inventor
PorKen's Avatar
Connector by jump post is one part of the towing package for automatics.
A temp switch, which replaces the plug below, turns on the electric fan according to the trans cooler temp by going to ground.
Old 09-21-2015, 09:28 PM
sydneyman
sydneyman's Avatar
lol. makes sense, thanks!
wow good to know! Thanks so much!
Old 09-22-2015, 11:37 AM
Alan
Electron Wrangler
Alan's Avatar
The connector under the hatch latch is certainly for the electric hatch opener. Since I assume you still have the mechanics in place for the hatch opener you could install a VW opener instead if you wanted a reliable means of opening the hatch - search for details on this. I would not reinstall the hatch motor - its absence indeed suggests it wasn't working right anyway.
The relay is stock, and is a 3 wipe delay relay for the rear wiper, you can replace it with a generic Bosch style SPST/SPDT to get 1 wipe functionality.
Alan
Old 09-22-2015, 11:41 AM
Alan
Electron Wrangler
Alan's Avatar
Note that the battery ground strap (to the wingnut) is not original, the original style is a black plastic sheathed flat braid, I'm not sure if the wingnut is stock either - I don't recall exactly how they look, my MY doesn't have one - but that doesn't look quite right to me... anyone?
Alan
Old 09-22-2015, 11:46 AM
MainePorsche
MainePorsche's Avatar
Alan
Wing nut looks right, but the cylindrical cable does not.
Old 09-22-2015, 11:47 AM
soontobered84
soontobered84's Avatar
Wingnut looks right to me. Ground cable is aftermarket.
edit: Verstand beat me to it.
Quick Reply: help identifying some PO presents.
