New member
#61
Subscribed.
When you completed the descriptions of your efforts with "but it's fun". I thought, yup, that is what it's all about. Sometimes I have to remind myself that when faced with what seems like daunting, PITA jobs.
Glad you're sharing.
#63
Fun work!
THANKS,
#64
Tires & Wheels
Thanks....they're turbo twist that came with the car. I've never driven the car...I bought it none running. I've since got the engine working, now swapping transmission just so I can get this beast moving. New tires will be next after I get her on the road....well, there is a long list of next projects for this 928.
#65
Worse case scenario would be...removing the axle shaft...so you could maybe push the wheel sensor out. I've drilled many directly in the center, like you mentioned...and that can work, too.
Good luck, and even though you've ran into quite a few snags...you are making headway...great work!
Brian.
Brian.
Brian; I went with drilling out...lots of patience gutting the sensor out and tapping the sensor walls in with a very thin chisel. Now I have to drill out what's left of the bolt. What do you do, or put around the sensor, that will keep this from happening?
THANKS,
#67
Fixing battery box rust
Well; I couldn't move any further and not address the rust on the bottom of the battery box. I've never metal fabricated anything, but I'm doing it.
#68
Battery box welding
These are the ugliest welds you'll ever see, but it's my first time. Anyway, I'm going to bring them down and re-stitch till I get it perfect...well, as perfect as I can get it:
#69
Looks like a pretty nice repair, especially for a first time welder. Keeping the welds small will make for much easier grinding. Just stitch in the unwelded areas and grind down. Most folks goober up the area with tons on unnecessary welding...which leads to much necessary grinding.
Keep up the nice work.
Brian.
Brian.
#70
Brian.
Brian.
#74
Going it
Finally putting things back together...TT and Transmission attached, all torqued in, fresh diff fluids, ready to go in. Nobody said it was going to be easy!
#75
Almost in!
Yesterday I had a couple hours to work on the car. TT lifted and ready to bolt in, rear diff strapped in....labor intensive....just takes time!
