Super charger belt coatings
Archive Gatekeeper
Belt coatings, or pulley coatings? Are you having issues with slippage?
Slippage also depends on the degree of pulley wrap by the drive belt, and depending on the type of compressor, the ratio of the sc pulley diameter to the crank pulley diameter..
Large diameter idler pulleys also help keep the belt temperature down and reduce friction in the system.
$0.02
$0.02
