Mismatched chips killing mileage
Chronic Tool Dropper
There's a BIG difference between the booster check valve and the the check valve by the booster that helps maintain vacuum in the reservoir for the HVAC and cruise control systems, and for the intake flappy control on S4+ cars. The booster check valve plugs into the grommet on the brake booster itself, helps maintain vacuum in the brake booster only.
Oh jeez, didn't know there were two different check valves. I'm pretty sure we only changed the one with the booster grommet (cuz I got that part from Roger to go with the check valve). Interesting, then, that it fixed the comb flap issue. Could simply have been bad lines/connections. But I will see about the *other* check valve next time. . .
The check-valve for the HVAC/Cruise/Flappy reservoir has small tubing nozzles at both ends of a small 2-colors barrel that's about the diameter of a dime.
The brake booster check valve gets the ~10mm ID hose from the eductor (commonly somewhat misreferenced as a venturi) next to the throttle quadrant on the side of the intake manifold. It slips into the booster grommet with a similarly-large single-barb nozzle. OD of the check-valve section is about an inch or so.
OK here's a baffling statistic -- after 2 or 3 tanks of 11 mpg, my mileage is improving significantly. I'm now over 12 mpg on my last tank, which is what I had generally run in all-city conditions in hot weather using AC over the past 5 years.
By what miracle would mileage improve spontaneously? How long does the adaptation circuit take to figure things out?
