cold air intake
I would just use a naca duct in the same place as the 968 turbo. I would of course use twin ducts. I figured this looks pretty good because the 968 has a sort of similar front end as the 928. I have a photo if you can't find one.
The air intakes originate in a high pressure area in the very front of the car, above the radiator. As long as the car is moving, I think it's already getting the coolest air available. I've seen this come up before and I don't get it. Somebody correct me if I'm missing something here.
Originally posted by onebad928s
i removed the fan shroud where the air intake tubes originally went.
You are reducing the pressure on the intake tubes and radiator when moving, and allowing hot air to recirculate back into the intake tubes when you are not moving. Bad idea.
old & new,
i know that, thats why i was asking about a cold air intake set up.The fan and shroud was taken off and replaced with electric fan,also the smog pump set up and a/c compressor was removed.
Lou
83 928 5 speed
Lou
83 928 5 speed
Originally posted by Old & New
Put it back, Lou.
Put it back, Lou.
Gosh, Lou, did you do a search on this? There was an exhaustive thread on this topic a couple months ago - the one where the guy had removed his air box cover in search of power gains.
old & new,
i did read that and it seems he was sucking hot air from around the motor just like the old hot rods.Im trying to design or see what other people have done to get in front of the radiator.Like all those guys who supercharged there 928s.They had to take the ait tubes off also but how were they avoiding the hot air from behind the radiator
Lou
83 928 5speed
Lou
83 928 5speed
Cut holes in your hood...
Fresh air straight into the intake tubes...
The old Strosek cars did it...
http://www.thedeathknight.com/928/928RedStrosek.html
If you search that older thread more thoroughly, you will see that there was a pretty cool idea, to have the hood "sandwiched" so it had a 1" gap for the air to pass from over the radiator, over the whole engine through the hood passage, then down into the air cleaner, thus eliminating the air tubes...
