How to Replace L-Jet Fuel Injector Hoses
We also offer an L-Jet Injector upgrade.
http://www.928motorsports.com/parts/ljet_injectors.php
We have new injectors with the same low impedance (required for the L-Jet) that seal in the conventional way - O-ring into the manifold and O-ring into the fuel rail. Gone are the little hoses!
To use these injectors, you must install a late-model fuel rail or our aluminum fuel rail.
These are really good for modified L-Jet motors - because I can have them made in 24 lb/hr (L-Jet 928 stock) or in 27, 30, and 36 lb/hr depending on your needs.
