Digital Dash Terminal question
While I have been able to trace the majority of the terminals on the 4 plugs on the digital dash, there are a few remaining that I am not sure exactly what they do. I have followed them on the wiring diagram but I am not sure what their purpose are. Does anyone know?
Plug 4, Pin 1 - Terminal 15 Cargo. Exactly what does this do and what is different from regular ignition power?
Plug 4, Pin 6 - Speed. Is this the input for the speedometer?
Plug 4, Pin 7 - Terminal TD. What is this?
Plug 2, Pin 10 & 11 - Radio TX/RX. What is the purpose of these connections?
Any insight would be greatly appreciated!
Cheers!
Carl
Cheers!
Carl
My guesses ...
Plug 4, Pin 1 - I have it noted as "Term 15 to CE" which I believe is 12V switched power?
Plug 4, Pin 6 - Speedometer signal
Plug 4, Pin 7 - Tachometer ("Term. TD") signal
Plug 2, Pins 10 & 11 - nothing on these, may not have been used on GTS?
