928 Forum 1978-1995
Sponsored by: 928 Specialists
What to do ?
Old Jul 7, 2015 | 01:56 PM
MainePorsche's Avatar
MainePorsche
Hey there Andre.
What you want to do with all the lines is see if they HOLD vacuum by using a MityVac. With the lines that go to the flaps, if they don't hold vacuum it means the diaphragm is likely torn (most common) or the line itself is faulty somewhere along its course. The line that goes to the heater valve should operate the valve arm when vacuum applied, and hold it's vacuum. The vacuum source line should have adequate vacuum when engine running. 20ml H20 comes to mind, but check the value on this from the write ups.
You can 'tie off' the heater valve arm for the warm weather. You might miss it on a cool morning in our part of the world. Do a Search on this. There is a good thread on this with pics. It involves drilling a small hole in the arm so you can tie a wire around it. It is kind of awkward otherwise.
Best Wishes.
Craig
Old Jul 7, 2015 | 02:04 PM
Andre The Giant's Avatar
Andre The Giant
Originally Posted by MainePorsche
Hey there Andre.
Best Wishes.
Craig
Thank you Craig. The more info I have the more I will be able to decipher this. All the help I have received so far is sure to get me started. I am still doing some more research as I go.
Old Jul 7, 2015 | 05:12 PM
Turc928S4's Avatar
Turc928S4
Hi André,
for your Info I do have a MityVac if you need one. Just sent me a PM and I could drop it or you could pick it up.
Sylvain
