928 Forum 1978-1995
Sponsored by: 928 Specialists
Twofer
Old Jun 21, 2015 | 03:55 PM
WALTSTAR's Avatar
WALTSTAR
Default Twofer
Can anyone tell me why the voltmeter is known for inaccuracy and how to get it to read correctly? I measured the voltage at the battery and am at over 13 volts but the gauge says less than 12.
Also, I removed the AC compressor and evaporator and formerly left the auxiliary electric fan in the car. Would it work without the AC system in place? If so, I will reinstall it. I have since removed it when installing the timing belt, water pump, and new tensioner (easiest car to do all these jobs on in my experience. Way better than working on a Northstar)....
Old Jun 21, 2015 | 03:59 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
depending on the wiring it, the fan should would if the temp switch in the radiator trips it.
as for the volt meter, clean all the grounds at the pod, and the connections can help. i alway just look at it and "add 1" to what ever it says.
Old Jun 21, 2015 | 04:29 PM
WALTSTAR's Avatar
WALTSTAR
Sounds like a plan. I will reinstall it. I do remember it running once. When I take out the dash to cover it, I will do the grounds.
WALTSTAR's Avatar
WALTSTAR
Nice rack in your avatar, by the way.
Old Jun 21, 2015 | 08:23 PM
OTR18WHEELER's Avatar
OTR18WHEELER
You can call me Otis
I think that's his daughter,
Old Jun 21, 2015 | 08:59 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Thank the Maker she is not..... LOL
Old Jun 21, 2015 | 10:08 PM
WALTSTAR's Avatar
WALTSTAR
I would have questions about the man that displayed his daughters charms so openly!
Old Jun 22, 2015 | 12:00 AM
James Bailey's Avatar
James Bailey
There is an adjustment on the voltmeter....search " low voltmeter adjustment screw" and it will pop up...
Old Jun 22, 2015 | 08:54 AM
jwyatt8171's Avatar
jwyatt8171
Good to know James. My Volt meter reads low, but the PO replaced the alternator and the battery(2x). I should put the Fluke on it to test.
TY for the info
Old Jun 22, 2015 | 08:54 PM
WALTSTAR's Avatar
WALTSTAR
Thank you James. I will look it up.
