Bad L-Jet?
#31
Go through all of the diagnostics I have provided above and report your results. Also, clean your grounds regardless of what your multimeter shows you in the way of resistance. This pertains to all of your grounds. Not just those that provide grounds for the L-jet.
Not much about your situation with your car is making sense yet and we need to know more at this point.
Are you aware of the thermo time switch? Is it plugged in?
Sometime soon after you get it going, I would strongly suggest replacing those fuel hoses.
I will say that when it starts it rumbles longer than it was before it dies. Still no noid light activity.
I take that back, the ground on the drivers side is unchecked, and an important one. I was trying to avoid pulling the pod and cluster but it looks I'll have to do that.
This car is killing me.
#33
Timing has nothing to do with injector pulse. Please follow the diagnostics from the WSM. You have already verified grounds pertinent to the L-jet. Get your numbers together and report back.
As far as the car killing you goes.. It will do a lot more of that if you don't make educated advances in your effort to resuscitate it. Start throwing parts at it and taking shots in the dark and you'll begin a long journey of frustration.
I'm limited in the way I can help to your willing effort to follow the diagnostics provided.
Let's get this shark breathing!
#34
And to tell you the truth, a couple ground points are escaping me, one of the rear ones, which is supposed to be forward and under a plastic cover - I found nothing there.
I may record some measurements later tonight, watching my Golden State Warriors try to win a game!
Thanks again Kiln_Red, if we get this puppy running, I'll name a set of new fuel lines after you!
#35
#37
sorry but this is simply painful...... STOP trying to FIX stuff and check out the brain ....more often than not in "fixing things" people create more problems than they solve !!! Like pulling the C E board...in nearly 20 years with my 1980 I NEVER needed to pull and clean it....NEVER ... changed a couple relays but ONLY when they failed...
#38
#39
The AFC relay and ignition switch may be ruled out at this point if you're sure that you observed 12V at W2, W3, and W5 of the CE panel.
You say you had very low voltage at W4, but 12V at pin 29 of the L-jet connector. This doesn't make sense as pin 29 is downstream of W4 and terminal 87 of relay XVI. W2 is one bank of injectors and W3 is the other. You said you had 12V for both injector banks at plug W, yet no voltage at the injectors.
No sense in trying another brain until you follow the WSM troubleshoot guide for AFC cars first. Trying another L-jet ECU may be the next step though.
#40
The car will start, run for a second or two then stall.
#42
#43
#44
It runs!!!!!!!
Here is the culprit. I'll need to order a new one, but once I wiggles it a little, more to love it out of way, a lot of the plastic insulation broke away. I pulled it out, cracked off the remaining insulation and reinserted it and crank and it ran!! Now because it hasn't ran in years, I'm nervous about letting it run to long.
Holy $@#!\*¥ I thought I would be chasing this problem for years.
