84 928S Negative Battery cable
Well guys, I think I have figured out the culprit of my car when it doesn't want to turn on. I do believe its my negative battery terminal. Every time it doesn't crank, I disconnect the negative and put it back. It allow my v
Car to start right up.
I need to know how to replace it since the cable strands are breaking one by one.
I don't see any diy tutorial for this but any information would help!!!
You just need to remove one end from the battery and the other end is held on by a single bolt underneath the toolkit cover.
Make sure the connection to the battery is tight. Loose connection can cause problems.
Electron Wrangler
That is not a stock cable - it should be flat & braided. For that to fit someone must have butchered the battery box lid... get the proper thing from a 928 vendor...
Alan
Alan
You need to inspect and either clean or replace all your grounds. There is a diagram showing all the ground points. I did all mine and it made a huge difference. also DeOxit as many electrical connections as you can. The difference will amaze you. Very cheap upgrade.
Basic Sponsor
We stock the flat ground cable for $29.25.
Yea I was searching it and noticed it was flat so I wasn't sure. But unfortunately I needed it right away and bought a negative cable from O'Reilly for 16 bucks. If it goes bad and have time I will purchase the correct one.
Team Owner
the only time the wrong ground strap will go bad is when your 400 miles from home at night and its pouring rain,
You hit the key and hear .... raindrops keep falling on my head.
pauliegirl (05-10-2023)
Ouch, that must've sucked! My car almost left me back in the box this past Saturday, I guess it was telling me "you need to fix my *** or next time I'm leave you..lol"
Team Owner
yes sir, your machine will talk to you ,
the trick is paying attention to what the message is and doing something about it
