Battery Maintainer Recommendation
Battery Tender. I have a connector mounted to the front of the car. I actually plug it in each night after i drive it.
I have been chasing a hot start issue for ages. It appears to comes down to a point where the injectors will not fire if the battery voltage reaches a certain point...why??...i dunno...what is causing it??.i dunno. Only seems to happen during the heat of the spring-summer months. Ever since i have kept the battery constantly at near full charge with the battery tender, i have never had an issue.
Very few of the better maintainers can be used as a power supply. As Denny says, they need to see a minimal battery voltage before they supply any power.
Most newer battery chargers work the same way, which means that they won't charge a battery after it gets really low. The work-around is to hook up the battery charger to the dead battery, then hook a good battery to the dead one with jumper cables. After an hour or two, you can remove the jumper cables and battery..
As said before the Ctek 7002 or what I use is the Ctek MXS 5.0 Test and Charge, besides beeing a normal battery maintainer, also tests your battery and alternator output! I'm very happy with it!
http://www.ctek.com/pt/en/chargers/MXS%205.0%20TEST%20AND%20CHARGE
Regards
Regards
Thanks for all the input, guys. I ended up going with the CTEK 7002 and am pretty happy with it. I have it recharging right now and all is good.
Tony - I'm curious as to how you have your's mounted? To the + pole at near the front of the engine and then the neg to the frame? And where did you place it as to not be affected by the heat & elements of the engine compartment?
I have two of these, except mine are re-labeled for Interstate Battery.
My local indy shop (Page Auto) always has one in stock:
Mine is that way, I've had batteries so low I had to first put them on a 12V 6amp charger for a bit, then the maintainer.
I hate that about my Denali. I drive it so infrequently I've killed the battery by leaving something like my V1 plugged in.
Alan
