Location and wiring of bulb control module 1983 euro S
Hello!
I think I might have an issue with the bulb control module on my 1983 Euro S. The right tail light is out and gets no power (remaining lights work fine though). Have not been able to find the bulb control module and am not sure how to bypass it if it proves to be faulty. Anyone able to assist me? Many thanks!
I just did the same fix two days ago. The right side (Passenger) tail lite and side marker lite are on the same circuit. Check the fuse first. check the bulbs second. The connecter plug for both of these is behind the interior panel at the very back of the car at hatch area. Difficult to access. Passenger side. Mine had two problems, the tail light was intermitant on /off, and the side marker light was dead. Both problems were bad or broken connector pins at the plug. Resoldered or replaced and all is well. Check this out before you tear open the bulb module, they rarely go bad.
Hello!
I had exactly the same problem also on the rear right side tail light, sometimes it lights but most of the time it was out, and I was sure the bulb was ok, it was driving me crazy not to know what was the reason!
My electrician follow all the wiring, it was all ok, and finally open the bulb control module and it was a little solder that was bad, re-soldered it and all it's ok!
Hope this help! Good luck!
Regards
It is often the module. With a little study you can bypass it. Several of us have posted the wiring bypass before.
Also, 84-on units are backward compatible with the 83 and back design.
