Sunroof Motor Clean - Worth Doing
Currently in the process of a fairly robust internal cleaning (all started after I purchased a $0.49 door clip...one thing lead to another and now I'm down to nearly the metal).
I'm going to take the headliner off soon to do a clean / SEM job, and was considering taking the sunroof motor off and going some cleaning on it.
The sunroof ran very slow, and I suspect that the track lubricant is probably gummed up (going to clean it up regardless), but I was considering removing the motor and cleaning up things up on it.
I saw a post from where Ducman chimed in saying that the motor refresh isn't terribly difficult.
Should I leave well enough alone? Or do I take the opportunity to tidy up a motor that's been in service (and probably not maintained) for the last 30 years.
When you take the drive cables off to clean and lube them, run the motor without them attached. See how it runs.
Make your decision from that.
I can't comment on the sunroof motor, but I did my windshield wiper motor (replaced the bearing and cleaned it up a lot) with minimal trouble.
You can call me Otis
This was one of the first things I messed with when I first got my car, took mine apart, but it was an hour or so wasted, motor mechanism was fine.
There is a brass toothed gear that uses friction like a clutch. That little slotted screw needs to be in and tight . I found it in the console after I r&r'd the motor.
Problem was the switch
To the OP- don't lubricate the track- only lubricate the "wire" with some gold grease. Lubricating the track only slows it down when some gritty substance inevitably lands on it.
Details are in this thread:
https://rennlist.com/forums/928-foru...-overhaul.html
Assuming that the Gold Grease is , wouldn't using a solid grease ultimately lead to the same gunking up of the track?
