Air pump delete question
Pretty much all the threads detailing this job are happening during a timing belt job. I guess this is due to the air pump actually being attached to the timing belt tensioner. Can I remove the air pump on it's own? I'm leery of messing with it if it's something that the tensioner is attached to.
I have an x-pipe that I'll be putting on, so I won't need the air pump, and as I wrestle with my AC issues, it would be a lot easier to get to the hose connections on top of the compressor if the air pump weren't in the way...
Yeah, that will work for putting on the x-pipe and taking off the air pump plumbing down there, but unfortunately does nothing to improve compressor hose access....but it is what it is, I guess....
1 Post
Unless you're going to remove the heat shield over the compressor., removing the air pump won't gain you a heck of a lot of space.
Make sure you disconnect the clamps that hold the hoses to the side, with that off they move around much easier.
