MY 85 TPS harness
Is it possible to change the TPS harness with leaving the intake in place ?
If not would it be easier just to remove the sides (plenums) of the intake only ?
I can't see where the TPS connects to on the throttle body side, the other side no problem of course.
I will also be looking at PET to see how it is and doing some research also, but I'm sure there are others on this forum that have done this on a 928S before that could give me some pointers, pictures would be a bonus since I am not completely versed on all the terms yet, only my second year with this car.
Do you know if there is anything connected to those plenums besides the brake booster connection on drivers side ? I would not want to pull hard only to find out that I broke something I could not see ?
Thank you Dave, I hope to get a chance to do this tonight, but I will not push my luck too much since my wife wants me to do some yard work, since I worked on the car all weekend.
Can't help U w/ yard work, too much of my own neglected to do list
Yes, if you have the "stock" Air-pump and CAT's then there is a 10mm bolt on each plenum (at the rear) attaching the "test tubes", most i've seen are rusted off at the exhaust header and should be plugged down there if not being used.
Can't help U w/ yard work, too much of my own neglected to do list![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Thank you again for your assistance. I will update this thread after I have checked the bolt location live and input more pics to confirm.
Here is an update with some pics. After removing the sides of the air intakes, from the right side I can't see the TPS connection and from the left side I can see the rear portion of the TPS but not where the connection is made. I can see the connection deep inside from the front on the passenger side but how to access it is the real question ? If I don't have to remove the intake I will be a happy man.
If I do access it from the front with a long pair of needle nose pliers, do I squeeze the plug horizontally or vertically to squeeze the clip so I can start pulling on it ?
The center T on the intake doesn't want to come out, I can tilt it to it being almost out but it seems that on the drivers side there is what looks like a 1-1/4 hose below the centre of the tube which I have no idea how to remove/disconnect can someone assist, please. I have taken the small 1/2 inch tube which was connected to the left side of the center tube when working from the drivers side.
Received 1,298 Likes
Sorry but can't help you much on this.
Maybe you'll find helpful tips here:
http://scott-yoo.com/other/intake.html
I was going to do a refresh of spark plug wires and plugs and intake next year, now is not a good time ! Oh well, i will keep on pluggin, next step is to purchase a set of long nose pliers in the range of 11 inches or so, just so I can try and reach that plug through the cubby hole in front.
Thank you all for your inputs.
Craic Head
Hey Andre, I responded to your PM. When I did it, the only way I could get my unusually large (and manly) hands in there
was to remove the side box and the ISV so I could get my left hand in and under.
I think I used a phillips head bit on a wrench or something to remove the two screws holding the TPS in there. I replaced them with allen bolts so I could do it again more easily next time (if necessary). I think the screws have some threadlocker on them too, so it's easy to strip those screws if you have a bad angle. Add to that the fact that it's adjustable and you have to find the right spot before locking it down and the screws may get a little buggered.
Hope this helped.
Hope this helped.
Hey Andre, I did that a couple of years ago and I recommend just taking this intake off. It doesn't take more than about a half hour and it exposes everything. The connectors on the TPS cable can be replaced, if you haven't bought the whole harness it's a lot cheaper to just rebuild it. Let me know and I'll look up the name of the connector, I can probably figure out where I got them too. I actually have a couple extra since they were cheap and I was worried I might screw one up. I'm pretty sure they're a Bosch part but that's just from memory.
Andrea, as Dave said replacing the TPS harness can be done, but you need to remove the "T" over the throttle body. There should be two large hose clamps over the rubber sleeve. One at the bottom that seals the sleeve to the throttle body and one on top that seals the the sleeve to the "T". You just need to loosen the top one and I was able to loosen it from the passenger side with a long screw driver. But it really depends on how that hose clamp is orientated. There is also a rubber hose connected to the "T" with a small hose clamp that you can get to from the driver's side. Once the "T" is loose from the large clamp it doesn't just pull up. You need to angle it just right to get it up past the rear and front intakes.
I don't remember if the small hose connected to the "T" goes to the ISV or out to the front of the engine.
With the "T" out you will be able to see the harness connected to the throttle body easier from the driver's side. If you are tall enough you might not have to lay over the engine like I did. I used a bent nosed needle nose to remove and install the harness.
Taking the intake "T" out is the easy part. Getting it back down and into the rubber sleeve is the bitch. I had my airbox and MAF out and reached my left arm (standing on the passenger's side) under the rear intake with a small plastic putty knife to help guide the "T" into the sleeve and keep rubber sleeve from pinching. My right hand was holding and wiggling the "T" into place. It took me very many tries to get it to seat correctly without any pinched sleeve areas. It will sit nice and stable when it's in correctly.
Hope this helped.
Hope this helped.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
For tonight I am done and here are a couple new pics of where I am now.
