AC speed relay test process
I assume the purpose of the AC speed relay is top keep the AC compressor from loading up the engine for better/ easier starting?
Out of Habit I have always turned off the AC at the controller before shutting off the car so consequently the AC is never on when starting the car.
If the above is true is there any issue just putting a jumper between pins 30 and 87 and using continuing the habit of shutting off AC with the controller?
