RIM WHEEL QUESTION
In general the front wheel offset 60 - 65 is good, 55 - 60 marginal, and less then 50 is too low. It has to do with front suspension geometry - negative scrub radius, bump teer and such.
Chronic Tool Dropper
Besides the suspension/steering geometry issues, that front will rub on your fenders.
Rears will work, the fronts will rub like a motherf*****. With that offset you should only run 7.5's. However, staying as close to 60 et is advisable.
