GT brake calipers
Archive Gatekeeper
Yes. All '89-91 fronts and all '89-95 rears are the same. The caliper piston seals changed in '89, which is important only because (at least 2-3 years ago) the old 87-88-style seals were NLA for rebuilding purposes, if that's an issue.
![](https://webfiles.uci.edu/redwards/public/TSB%20calipers%20with%20improved%20seals%20MY%2089%204-14-15.jpg)
Rob,
the calipers are still the same from model year '87-'91 in the front and rear and only the seals are different or are the calipers different too from '89-'91?
Rich
Rich
Archive Gatekeeper
Hi Rich-
The actual shape of the recesses in the calipers where the dust seals seat is different, both front and rear.
Here's a '90 front caliper showing the recesses,
![](https://webfiles.uci.edu/redwards/public/Front%20caliper%201990%20showing%20dust%20seal%20recesses%201-3-09.jpg)
And a new GTS caliper showing the dust seals:
![](https://webfiles.uci.edu/redwards/public/GTS%20front%20caliper%20pistons%208-11-11.jpg)
